Gas dryer heats up then goes to cool. Needs parts numbers for both the gas valve coil kit and the hi limit thermostat. Or if it could be anything else? Thanks
Hello, Does the flame ignite every time when the igniter goes on? If it does not not then the problem is a bad gas valve coils. - The gas valve coil kit Part number: 279834
Gene. P.S. The model number you posted is incorrect.
