WilliamJ1
#1 Posted : Monday, December 31, 2012 12:00:19 PM(UTC)
WilliamJ1
After opening my refrig. door for 5 seconds,the compressor turned on.
It ran for approximately 5 minutes, then turned off.
The compressor fan started back up,then off.
I hear a clicking sound while fan is on,then the compresor turns back on.
It runs for 2 min. then turns off.
While the comp. fan was turning on/off, I turned the temp control thermostat down to a warmer setting and everything turns off.
Help please !
#2 Posted : Tuesday, January 1, 2013 1:41:19 AM(UTC)
I would drop the control panel and let it hang on the wires. Tap on the cold control and defrost control, one of them might be intermitent.
If ok, I would next check the connector for the control panel, unplug it and plug back in, might have a bad pin.
WilliamJ1
#3 Posted : Tuesday, January 1, 2013 12:50:37 PM(UTC)
WilliamJ1
Ok thanks, I'll try that and let you know !
WilliamJ1
#4 Posted : Sunday, January 13, 2013 4:24:18 PM(UTC)
WilliamJ1
I dropped the control panel, tappped the cold control and the fan shut off.
I've done this on several occasions, sometimes not even dropping the control housing and actually tapping on the housing.This too, is shutting off the fan.
Does this indicate that the cold control is faulty ?
#5 Posted : Monday, January 14, 2013 12:19:16 AM(UTC)
I would take the screws out of the cold control to isolate it. If it still shuts off when tapping it, that confirms a bad control.
WilliamJ1
#6 Posted : Monday, January 14, 2013 1:22:45 PM(UTC)
WilliamJ1
What do you mean, when you mention "screws" ?
#7 Posted : Monday, January 14, 2013 6:27:10 PM(UTC)
Remove the control from the control panel.
WilliamJ1
#8 Posted : Monday, February 25, 2013 6:32:49 PM(UTC)
WilliamJ1
Sorry I haven't responded sooner on this.
It was the cold control that was faulty, after testing it.
I have since replaced it .
Thanks for your help !
Bill
