Bottom Oven Broil: top element turns cherry red Bottom Oven Bake: top element turns cherry red, bottom element stays cool. Temperature does increase to desired temperature. Both elements and probe have continuity.
Top Oven Broil: top element does not heat Top Oven Bake: top element does not heat, bottom element does not heat. Hear clicking sound but temperature displays only to 135 degrees preheat. Both elements and probe have continuity.
What needs replaced?
Groups: APP Team
Hi. Based on the info you provided there are two problems. The lower oven need a new relay board (assuming that you took off one wire from the element when measured the continuity) Part number: 318022001
For the upper oven you should check if the thermal resettable switch is open.It's on the back of the oven ,but you should be able to check it from the upper relay board . Check continuity from Yell/Blue wire BA to one of the brown wires from the DLB relay. No continuity - remove oven and reset the switch. If the switch is OK - replace the upper relay board Part number: 318022002
safety switch and all elements have continuity.. will order both relay boards. Originally Posted by: Simon / APP Team ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Hi. Based on the info you provided there are two problems. The lower oven need a new relay board (assuming that you took off one wire from the element when measured the continuity) Part number: 318022001
Groups: APP Team
Please, keep us posted.
Simon.
