a029342
#1 Posted : Tuesday, December 18, 2012 10:48:46 AM(UTC)
a029342
Bottom Oven Broil: top element turns cherry red
Bottom Oven Bake: top element turns cherry red, bottom element stays cool. Temperature does increase to desired temperature. Both elements and probe have continuity.
Top Oven Broil: top element does not heat
Top Oven Bake: top element does not heat, bottom element does not heat.
Hear clicking sound but temperature displays only to 135 degrees preheat.
What needs replaced?
Simon / APP Team
#2 Posted : Tuesday, December 18, 2012 6:16:20 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Based on the info you provided there are two problems.
The lower oven need a new relay board (assuming that you took off one wire from the element when measured the continuity) Part number: 318022001
For the upper oven you should check if the thermal resettable switch is open.It's on the back of the oven ,but you should be able to check it from the upper relay board .
Check continuity from Yell/Blue wire BA to one of the brown wires from the DLB relay. No continuity - remove oven and reset the switch.
If the switch is OK - replace the upper relay board Part number: 318022002
The thermal switch Part number: 318004900
Here are the breakdown diagrams and Control Panel parts for Frigidaire GLEB27T8CSA - AppliancePartsPros.com
Post the results.
Simon.
a029342
#3 Posted : Tuesday, January 8, 2013 12:54:34 PM(UTC)
a029342
safety switch and all elements have continuity.. will order both relay boards.
Originally Posted by: Simon / APP Team Go to Quoted Post
Hi.
Post the results.
Simon.
Simon / APP Team
#4 Posted : Tuesday, January 8, 2013 1:19:30 PM(UTC)
Simon / APP Team
Groups: APP Team
Please, keep us posted.
Simon.
