weesel72
#1 Posted : Friday, December 14, 2012 10:17:28 AM(UTC)
weesel72
What are the ohms supposed to be on the circulation pump on a Frigidaire dishwasher? I have the proper voltage, no blockage, but want to know if the circulation pump motor is bad before replacing
sidfink43
#2 Posted : Monday, December 17, 2012 3:59:40 PM(UTC)
sidfink43
You have posted on the clothes washer forum.
If you will post on the dishwasher forum I am sure someone can help you.
One way to check the pump is to use jumper wires from a 120v source to see if the pump operates.
Good luck.
