What are the ohms supposed to be on the circulation pump on a Frigidaire dishwasher? I have the proper voltage, no blockage, but want to know if the circulation pump motor is bad before replacing
You have posted on the clothes washer forum.
If you will post on the dishwasher forum I am sure someone can help you.
One way to check the pump is to use jumper wires from a 120v source to see if the pump operates.
Good luck.
