bobgjr
#1 Posted : Monday, December 17, 2012 10:07:40 AM(UTC)
bobgjr
I have the Maytag washer MVWC6ESWW that is not agitating. Washer fills with water then stops. I can then hear the motor just hum and not agitate. I checked cap and it is good. The motor will however run to pump out the water. When the washer is in the motor hum state I can push the timer knob in just a little and the motor will start and the washer will agitate. The timer was replaced about 2 months ago. When the motor does run it smells hot. Any ideas? Motor? Timer again? Something else?Thanks
Simon / APP Team
#2 Posted : Monday, December 17, 2012 11:50:47 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
It does sounds like the bad timer. Check also the motor plugs for bad connection.
The timer Part number: W10243947
ramblinche81
#3 Posted : Monday, December 17, 2012 1:47:51 PM(UTC)
ramblinche81
Could be lid switch is bad. Move it to a different wash setting on the dial, if it still won't run the full cycle, $30 lid switch is a more likely cause.
Especially if you can use a pencil or small screwdriver to push the switch you should hear it click.
Simon / APP Team
#4 Posted : Monday, December 17, 2012 2:15:57 PM(UTC)
Simon / APP Team
Groups: APP Team
If the washer is draining it's not the lid switch.
Simon.
Maytag washer not washing or spinning (Washer Repair)
by ttdarkie 4/16/2010 3:12:13 PM(UTC)
