edm812
#1 Posted : Tuesday, April 14, 2009 7:16:24 AM(UTC)
edm812
Have the above mentioned dryer in our RV. It is a 110V. Dryer does not produce heat "all" the time. While using the same cycle and same load, may have to run 3 cycles. Sometimes, the dryer does not produce any heat for 2 of the cycles and then will be HOT on the 3rd try. Some times the door just gets warm. The exhaust duct has been cleaned and the dryer lint screen is cleaned each load. Thanks in advance for your help. Ed.
#2 Posted : Tuesday, April 14, 2009 2:26:16 PM(UTC)
The model number you posted is for a washer. Verify and repost it.
edm812
#3 Posted : Tuesday, April 14, 2009 3:46:22 PM(UTC)
edm812
This is to revise my earlier post. The correct model number for the GE dryer is DSKP333EC. Thanks again. Ed.
#4 Posted : Tuesday, April 14, 2009 8:10:40 PM(UTC)
Ed,
I would recommend to take the dryer apart, clean the air ducts and the blower housing and check the heating element. Make sure the blower wheel is not slipping.
Here are the breakdown diagrams and Replacement parts for GE DSKP333EC0WH | AppliancePartsPros.com
edm812
#5 Posted : Wednesday, April 15, 2009 5:08:23 AM(UTC)
edm812
Thanks Gene for your help!! Will checking for concentricity reveal the working condition of the element? Thanks again Ed.
intermittent dryer heat problem (Dryer Repair)
by busterhead 10/19/2012 2:28:25 AM(UTC)
