Yefim
#1 Posted : Monday, April 13, 2009 10:30:35 AM(UTC)
Yefim
Hi. In refrigerator at the buttom of the evaporator is accumulated ice and condenser's pipeis frozen. I cleaned up twice but ice is builed up again. What could be a problem? Thaks, Yefim.
woodchuckie
#2 Posted : Monday, April 13, 2009 3:32:57 PM(UTC)
woodchuckie
If the evaporator coils behind the back panel of the freezer are icing up and blocking the flow of air it is an auto defrost failure.
check defrost heater, defrost thermostat.
Refrigerator Repair Guide: How To Fix a Refrigerator - ACME HOW TO.com
If they are ok the problem is the pbm control, part 6 on your diagram.
http://www.appliancepartspros.com/sect/m/g/l/mglrm2rfis.gif
#3 Posted : Tuesday, April 14, 2009 3:09:55 AM(UTC)
When you say the condenser's pipe is frozen do you mean that in the compressor area under the fridge there is ice on one of the pipes leading out of the compressor before it enters the refrigeration compartment.
I think I saw something like this in a tech bulletin had something to do with a dryer problem.
Yefim
#4 Posted : Tuesday, April 14, 2009 4:06:15 AM(UTC)
Yefim
Hi. NO imean the condenser is inside refrigerator not a freezer. There is a drain that getting frozen and build ice under condenser. Thanks, Yefim.
woodchuckie
#5 Posted : Tuesday, April 14, 2009 6:36:25 AM(UTC)
woodchuckie
That is the evaporator inside. The condenser is outside. Anyway Your drain tube must be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little air pressure will usually clear it out. Flush it out with hot water and clorox may help. Make sure it drains quick enough. The drain should be located below the evaporator coils on the lower back of the freezer.
Part 6 on this diagram is your drain. http://www.appliancepartspros.com/sect/i/5/z/i5z1r5fadk.gif
Refrigerator Compressor Starting With Failed Start Relay??? How Can This Be? (Refrigerator & Freezer Repair)
by AppliancePartsAmateur 7/1/2024 5:18:48 PM(UTC)
GTS16DTNKRWW Refrigerator - Intermittent Operation (Refrigerator & Freezer Repair)
by seocom 6/22/2024 6:51:32 AM(UTC)
GE refrigerator/freezer side by side (Refrigerator & Freezer Repair)
by Pdynamo 6/20/2024 6:20:43 PM(UTC)
Kitchenaid refrigerator and freezer intermittently to warm (Refrigerator & Freezer Repair)
by Guest 6/18/2024 12:12:20 PM(UTC)
Whirpool WRF535SMBM Refrigerator (Refrigerator & Freezer Repair)
by goclones 6/16/2024 8:15:11 AM(UTC)
Samsung Refrigerator Pantry Drawer Support #SAM-DA61-03174A (Refrigerator & Freezer Repair)
by joecoliphant 6/15/2024 8:12:03 AM(UTC)
Ice behind fan pannels in refrigerator and fan not working (Refrigerator & Freezer Repair)
by Mark7604 6/9/2024 6:43:14 AM(UTC)
GTR22HBTARBB water leak to bottom refrigerator (Refrigerator & Freezer Repair)
by wilsonjiaho 6/8/2024 4:24:50 PM(UTC)
LG Refrigerator - Makes ice, but won't dispense ice nor water (Refrigerator & Freezer Repair)
by teamfindley 5/28/2024 7:48:32 PM(UTC)
samsung fd refrigerator (Appliance Repair Companies - East of the Mississip)
by gale reid 5/28/2024 3:17:33 PM(UTC)
Cold-Coldest setting on meat drawer on GE GNE25j refrigerator (Refrigerator & Freezer Repair)
by Guest 5/23/2024 11:20:53 AM(UTC)
Refrigerator freezer (freezer is above refigerator,) (Refrigerator & Freezer Repair)
by cwillman 5/16/2024 12:29:58 PM(UTC)
GE Side by Side Refrigerator Model GSS25IYNXHFS dim LED lights (Refrigerator & Freezer Repair)
by jhauter 5/15/2024 4:30:46 AM(UTC)
Refrigerator Ice (Refrigerator & Freezer Repair)
by Guest 5/9/2024 7:00:37 AM(UTC)
GE refrigerator Ice machine not working. (Refrigerator & Freezer Repair)
by Don718 5/6/2024 11:45:46 AM(UTC)
