My dishwasher won't drain...I have taken it apart, made sure there is no debris, made sure the hoses are unobstructed and I even replace the drain pump. Replacing the drain pump worked for about 2 weeks, and now it's not draining again...anything else I can do???
In order to provide most accurate advice we need the complete model number of the dishwasher.
Frigidaire Gallery, FGBD2431KF1...thanks Originally Posted by: Gene  In order to provide most accurate advice we need the complete model number of the dishwasher.
disconnected drain hose...ran through a rinse cycle with the drain hose in a bucket...no water came through though the hose is clear
Originally Posted by: brianlevenstein  ...ran through a rinse cycle with the drain hose in a bucket... Did it go through the drain cycle? Did the drain pump run? Gene.
