2 Pages12>
CAT88
#1 Posted : Thursday, December 6, 2007 11:47:36 AM(UTC)
CAT88
hi,Our washer is getting power to the computer board, but has no lights on control panel and will not work at all, Is there anything I can check for. Thanks for any help.Sincerely Craig
#2 Posted : Thursday, December 6, 2007 1:00:46 PM(UTC)
Craig,
You can find all troubleshooting instructions in the technical data sheet.
CAT88
#3 Posted : Friday, December 7, 2007 2:26:21 PM(UTC)
CAT88
Hi, well it looks like I will have to buy a cpu unit, No power coming out of computer board $150.00- $200.00 more into a $1300.00 dollar machine less than 3 years old. Thanks Craig
#4 Posted : Friday, December 7, 2007 3:32:38 PM(UTC)
The part number for the Central Control Unit AP3881119 and you can buy it from APP for $144.56 (compare at $199.49 from Sears).
WJerry
#5 Posted : Wednesday, December 31, 2008 11:27:27 AM(UTC)
WJerry
Hello - I am faced with this problem after installing the new control board (#8182221). Procedure so far: powered down machine, changed board, on power up I pressed cancel twice as instructed. The machine locked the door, flashed several lights and ended up with 3 dashes on the display. It would not respond to any further buttion pushing. I powered down the machine and manually unlocked the door. Repowered and it is now totally unresponsive. Any insight on what to do next ? Remember new control board.! Help....
Edited to add - Reinstalled old control board. Machine is now running and we are expecting more F11 and dL codes solved by wire wiggling. I'm guessing the new control board was defective.
lowlandman
#6 Posted : Monday, May 11, 2009 5:59:02 PM(UTC)
lowlandman
How do I know if CPU is dead? I am getting the sam --- display others have mentioned.
#7 Posted : Tuesday, May 12, 2009 11:03:52 AM(UTC)
What is the complete model number of the washer?
richardson
#8 Posted : Saturday, September 12, 2009 9:05:32 PM(UTC)
richardson
We had power outage for over 2 hours during a wash cycle for our Kenmore HE4t (model: 110.45986404) and now it will not power up. Dryer works fine and it's plugged into the same wall outlet. We unplug the washing machine and replugged. Still nothing. We had to manually opened to door to get our clothes out of the washer so they don't sit in the machine all wet. How do we drain the water inside the washer?
Any ideas on how to fix the power issue? I read the tech sheet posted above and we can hear power clicking to CCU.
Do we need to order a new CCU?
thank you!!!
#9 Posted : Sunday, September 13, 2009 3:05:04 PM(UTC)
Proceed with the steps 3 through 7 of "Possible cause/test", listed in the Tech sheet (page 14) for "Won't power up" problem and post the results.
richardson
#10 Posted : Tuesday, September 15, 2009 7:43:09 AM(UTC)
richardson
Gene,
We followed Steps 3-7, opened up the top, check all the connections. When we plug the power back, we can hear the clicking and very faint high pitch noise that rings for few seconds. No power to the LED/touch pad still.
We think maybe it's the control behind LED/touchpad is bad.
Any thoughts or help would be appreciated. Thank you!
Guest (10)
Kenmore elite he4t No power after ccu replaced (Washer Repair)
by junit 10/7/2011 1:11:36 PM(UTC)
2 Pages12>
