SHADETREE101
#1 Posted : 16 years ago
SHADETREE101
I Get A F2 Error Sometimes Time When We Bake. How Do I Find Out If Its The Sensor Or Control Board? Sometimes It Starts Beeping 20 Min. After We Use It And The Oven Is Off.
applianceman
#2 Posted : 16 years ago
applianceman
F2 indicates that temperature inside the oven has gotten to high. As you say it can be the sensor or the board. The sensor should read around 1000 ohms at room temperature if not it is bad. If it checks ok replace the board. Fault Code Clearing And Repair Guide
SHADETREE101
#3 Posted : 16 years ago
SHADETREE101
Where Can I Find A Wiring Diagram That Shows The Sensor?
SHADETREE101
#4 Posted : 16 years ago
SHADETREE101
which wires go to the sensor?
applianceman
#5 Posted : 16 years ago
applianceman
Pull the range out and remove the back cover. Look where the broil unit comes out the back of the range. Between the two terminals for the broil unit are the sensor wires. You will need to disconnect them before testing ohms. Note you may have to cut them. Be sure to disconnect power from range before doing so.
SHADETREE101
#6 Posted : 16 years ago
SHADETREE101
i have 1109 ohms. does this mean that the control board is bad?
applianceman
#7 Posted : 16 years ago
applianceman
[FONT='Times New Roman']Yes, replace the control board. [/FONT]
GE Error Code F2 (Oven Repair (including Ranges and Cooktops))
by jasonroach 13 years ago
Sear Radiant free-standing range error code F2 (Oven Repair (including Ranges and Cooktops))
by gregoz 14 years ago
Kenmore Range error code F2-E0 (Oven Repair (including Ranges and Cooktops))
by mtfurtney 17 years ago
