Main fan at bottom of refrigerator "click" starts and then "clicks" off. I can spin fan with finger freely. Fan motor not hot by touch. What is causing this? If possable includ part discription(s) and part number(s).
Thanks Frank
Click noise is probably coming from the compressor, not from the condensing fan motor, just check
Originally Posted by: richappy  Click noise is probably coming from the compressor, not from the condensing fan motor, just check You are correct compressor not working. So is it a relay or the compressor thats needs replacing? Whats the next step? Frank
The parts breakdown will not show the compressor. If you pry off the compressor side cover, your start device is probably a mechanical one with a coil. If so and you find no burnt wires, you probably have a bad compressor as these start devices are very reliable. Post what you find.
Originally Posted by: richappy  The parts breakdown will not show the compressor. If you pry off the compressor side cover, your start device is probably a mechanical one with a coil. If so and you find no burnt wires, you probably have a bad compressor as these start devices are very reliable. Post what you find. I purchased a new GE Refrigator, didn't fell like spending any more the time on the old one. Got over 24 yrs. of great service. thanks for helping. frd
