2 Pages<12
#11 Posted : Monday, December 3, 2007 9:59:35 AM(UTC)
To make sure the problem is not the lid switch I would recommend to bypass the switch and run the washer.
dannag
#12 Posted : Monday, December 3, 2007 11:34:29 AM(UTC)
dannag
My machine stopped spinning or agitating. It takes in water and drains fine and goes through the cycle. However there is no washing or spinning happening. It is worth fixing?
NickStamis
#13 Posted : Monday, December 3, 2007 12:58:48 PM(UTC)
NickStamis
Gene,
I won't be able to get to my machine fo r acouple of days. Let's assume that its not the lid switch, what should I check next?
#14 Posted : Tuesday, December 4, 2007 12:38:16 PM(UTC)
In order to provide the most accurate advise I need the complete model number of the washer.
Post it as a new thread, please.
NickStamis
#15 Posted : Thursday, December 6, 2007 8:22:26 AM(UTC)
NickStamis
Gene,
I see dannag has started a separate thread. Here is the info for my washer. Still looking to check the next thing. I will add that I don't hear any noises when the washer should be spinning or agitating. As I stated before if we assume the lid switch is working, it appears to me that another switch may have gone bad. Given the model info below, what switch should I test and where should I look. I agree it does not appear that the motor, transmission, or clutch are the problem, but I will defer to your greater experience.
Thanks,
nick
Model Number: wcsr2070tdww Brand: GE Age: 5 - 10 years
#16 Posted : Thursday, December 6, 2007 9:43:34 AM(UTC)
Nick,
If there is nothing wrong with the lid switch, then check wires from the timer to the motor.
Check the motor windings for continuity. I do not have the wiring diagram for this washer, but it could be inside the control panel.
If the motor tests OK then the problem is a bad timer.
NickStamis
#17 Posted : Friday, December 7, 2007 11:04:10 AM(UTC)
NickStamis
Gene,
I aremoved the switch from the circuit, washer works. I guess it was the lid switch all along. I'll order one this weekend and install next week.
Thanks!:)
Samsung Washer No Agitation or Spin (Washer Repair)
by amappliancewi 2/7/2024 10:24:03 AM(UTC)
Whirlpool washer-no agitation or spin; grinding noise (Washer Repair)
by Blaiser 7/8/2014 9:39:04 PM(UTC)
Loud noise, No Agitation or Spin (Washer Repair)
by Rick442 2/13/2012 5:14:04 AM(UTC)
GE Front Loader - Fills but no agitation or spin (Washer Repair)
by Happy Clown 11/8/2011 6:26:44 PM(UTC)
Washer pumps & Clicks and no agitation or spin (Washer Repair)
by KP11520 8/21/2009 1:37:34 PM(UTC)
slight grinding, no agitation or spin (Washer Repair)
by oilspot 12/12/2008 6:54:16 AM(UTC)
2 Pages<12
