jmclanton
#1 Posted : Tuesday, May 29, 2012 10:03:40 AM(UTC)
jmclanton
Rank:: Member
Ice stops dispencing, I have replaced the auger motor & hex cap (looked a litte worn). I removed the ice bin and ran the auger motor with door open and the motor runs fine for about 10 seconds but starts to bog down and stops running. After a couple mintues of letting is sit it will start up and then quit again. This is a new auger motor I purchase from Parts Select a few weeks ago and still can't figure out what is wrong with it not dispencing the ice properly. Please advise.
Simon / APP Team
#2 Posted : Tuesday, May 29, 2012 12:58:06 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Check the run capacitor Part number: 65889-4
The info is on the capacitor.
Here are the breakdown diagram and Freezer compartment replacement parts for Maytag MZD2663KEQ REF - SXS/I&W | AppliancePartsPros.com
Thank you. Post thew results.
Simon.
jmclanton
#3 Posted : Tuesday, November 27, 2012 8:35:17 AM(UTC)
jmclanton
Rank:: Member
Hi, I replaced the capacitor Part number: 65889-4 that was recommended but still having the same problem, it stops dispencing ice. Any other suggestions?
Thank you,
Julie M. Clanton:confused:
Simon / APP Team
#4 Posted : Tuesday, November 27, 2012 2:32:03 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Did it work for some time?
Simon.
jmclanton
#5 Posted : Saturday, December 1, 2012 2:36:44 PM(UTC)
jmclanton
Rank:: Member
It will run for about 20 seconds than stops but If I remove the ice bin and hold the button down it will run longer.
Simon / APP Team
#6 Posted : Monday, December 3, 2012 9:42:14 AM(UTC)
Simon / APP Team
Groups: APP Team
HI.
Can you check what is the voltage at the auger motor?
Simon.
jmclanton
#7 Posted : Monday, December 10, 2012 8:31:59 AM(UTC)
jmclanton
Rank:: Member
Originally Posted by: Simon / APP Team Go to Quoted Post
HI.
Simon.
110-120 V is what is on the sticker for the auger motor.
Julie
Simon / APP Team
#8 Posted : Monday, December 10, 2012 9:32:34 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi, Julie.
I asked you to check the actual voltage at the auger motor wile it's running. You need to use the voltmeter.
Simon.
jmclanton
#9 Posted : Monday, December 10, 2012 9:46:19 AM(UTC)
jmclanton
Rank:: Member
Hi, Julie.
Simon.
Don't have one.
Julie
Simon / APP Team
#10 Posted : Monday, December 10, 2012 10:23:35 AM(UTC)
Simon / APP Team
Groups: APP Team
Without doing the test my best guess it's a bad control board
Part number: 67006743
