2 Pages12>
csulzbach
#1 Posted : 12 years ago
csulzbach
The cooktop, broiler and warming drawer work OK but the oven stopped working. When any of the oven modes are selected, e.g. BAKE, the display shows PREHEAT then switches in just a few seconds to BAKE (it used to stay at PREHEAT until the oven temperature was reached). It then cycles back and forth showing PREHEAT and BAKE, but the oven gas doesn't come on. I'm thinking it may be the oven sensor. The ignitor does not glow red like the broiler ignigtor. Can you help?
Thank you
#2 Posted : 12 years ago
What is the complete model number of the range?
csulzbach
#3 Posted : 12 years ago
csulzbach
The model number is HGS346UC/01
#4 Posted : 12 years ago
There are two parts which could cause such problem: the relay board (more likely) and the main control board (less likely). Unfortunately both parts are no longer available.
csulzbach
#5 Posted : 12 years ago
csulzbach
How can that be? the oven is less than 5 years old. How can those parts not be available. could nt it just be the ignitor?
#6 Posted : 12 years ago
I understand your feelings. You have to ask Bosch why did they do it to you.
I don't think there is something wrong with the igniter because of the information shown on the display, but you can check it for continuity and measure the voltage to the igniter while the control calls for Bake.
#7 Posted : 12 years ago
In case if I'm wrong and the problem is a bad igniter:
- The igniter Part number: 492431
Part number: 492431
csulzbach
#8 Posted : 12 years ago
csulzbach
What should the resistance reading be across the igniter out of circuit? and what should the voltage read in circuit?
Thank you for such a quick response
#9 Posted : 12 years ago
In such situation the most important test is the voltage to the igniter. The normal reading should be about 120 VAC. Improper voltage reading proves a bad controls.
csulzbach
#10 Posted : 12 years ago
csulzbach
I also posted a bit of wrong information in my original post about the display. When I turn oven on and select bake then turn knob to 350 degrees. The display stays on preheat at 100 degrees it does not switch back and forth to bake. It just stays on preheat at 100 dergrees. Does this change the possible solution?
Gas Oven not heating up (Oven Repair (including Ranges and Cooktops))
by Guest about a year ago
GE gas oven not heating (Oven Repair (including Ranges and Cooktops))
by 1alembic 7 years ago
Gas Oven not heating correctly (Oven Repair (including Ranges and Cooktops))
by Malumake 11 years ago
GE Gas Oven not heating up correctly (Oven Repair (including Ranges and Cooktops))
by ichengsd 13 years ago
Gas Oven not Heating at all burners OK (Oven Repair (including Ranges and Cooktops))
by tattell 13 years ago
Amana ARGS7650 Gas Oven not heating (Oven Repair (including Ranges and Cooktops))
by reg71 14 years ago
Please Help!! Whirlpool gas oven not heating correctly (Oven Repair (including Ranges and Cooktops))
by Rebetimm 15 years ago
Gas oven not heating properly (Oven Repair (including Ranges and Cooktops))
by wandanyb 15 years ago
Gas oven not heating (Oven Repair (including Ranges and Cooktops))
by curtisn 16 years ago
Gas oven not heating at all! (Oven Repair (including Ranges and Cooktops))
by krakka 17 years ago
Older Gas Oven not heating up enough (Oven Repair (including Ranges and Cooktops))
by Meg70 17 years ago
gas oven not heating up like it should (Oven Repair (including Ranges and Cooktops))
by fillhardfarm 17 years ago
Gas Oven Not Heating (Oven Repair (including Ranges and Cooktops))
by defirechief8915 17 years ago
2 Pages12>
