defirechief8915
#1 Posted : 17 years ago
defirechief8915
Ok, went to bake, used the bake selector and set temp @ 350, but it would not heat up over 200. Assuming that everything worked as far as the gas and EOC, I replaced the temp probe. No good, but while messing with it, I noticed if I used the preheat, the oven would not ignite, but if I selected the bake feature, it will ignite but shut off after it heats for a while, any suggestions?
#2 Posted : 17 years ago
Hi
The first thing I would check is the bake igniter (#19 on the burners break down diagram). How long time takes for the igniter to light up the burner? If it takes more then 60 seconds the igniter has to be replaced.
- The part number for the bake igniter AP2150412
The bake igniter
UserPostedImage
- Here are the break down diagrams for the Frigidaire range Model FGF374CCSC
Good luck.
defirechief8915
#3 Posted : 17 years ago
defirechief8915
That's what has me confused, if I use the pre heat, it will not light at all, but if I just select bake, and set the temp, it ignites right away, but does not heat up to selected temp before the burner goes out, and will not come back on unless you turn it off, and start over.
#4 Posted : 17 years ago
I'm assuming you meant the oven temperature sensor when you said "the temperature probe" and you already replaced it.
If there is nothing wrong with the bake igniter and the temperature sensor has been just replaced, the only part which could cause such problem is the control board (aka clock).
- The part number for the clock AP2150420
I believe it should solve the problem.
Good luck.
Gas Oven not heating up (Oven Repair (including Ranges and Cooktops))
by Guest about a year ago
GE gas oven not heating (Oven Repair (including Ranges and Cooktops))
by 1alembic 7 years ago
Gas Oven not heating correctly (Oven Repair (including Ranges and Cooktops))
by Malumake 11 years ago
by csulzbach 12 years ago
GE Gas Oven not heating up correctly (Oven Repair (including Ranges and Cooktops))
by ichengsd 13 years ago
Gas Oven not Heating at all burners OK (Oven Repair (including Ranges and Cooktops))
by tattell 13 years ago
Amana ARGS7650 Gas Oven not heating (Oven Repair (including Ranges and Cooktops))
by reg71 14 years ago
Please Help!! Whirlpool gas oven not heating correctly (Oven Repair (including Ranges and Cooktops))
by Rebetimm 15 years ago
Gas oven not heating properly (Oven Repair (including Ranges and Cooktops))
by wandanyb 15 years ago
Gas oven not heating (Oven Repair (including Ranges and Cooktops))
by curtisn 16 years ago
Gas oven not heating at all! (Oven Repair (including Ranges and Cooktops))
by krakka 17 years ago
Older Gas Oven not heating up enough (Oven Repair (including Ranges and Cooktops))
by Meg70 17 years ago
gas oven not heating up like it should (Oven Repair (including Ranges and Cooktops))
by fillhardfarm 17 years ago
