bearkaye
#1 Posted : Saturday, November 24, 2012 1:27:39 PM(UTC)
bearkaye
I have read posts with washers with the similar issue - itermittent spin cycle. After draining, I can hear the motor continuing to run, but can tell the basket is not spinning. When I open the lid, the motor shuts off; as the motor spins down, the transmission sometimes clicks into gear. I can tell because the basket moves slightly. Once this happens, the basket spins properly. If I'm not around the babysit the machine, I often find soggy clothes in the bottom of the basket. I then have to reset the machine to a spin cycle and play the open/close game with the lid to get the transmission to engage. What part(s) do I need to replace to fix this issue?
fairbank56
#2 Posted : Saturday, November 24, 2012 2:55:57 PM(UTC)
fairbank56
Groups: Expert
After draining, the motor should pause for a few seconds and then start back up again to start spinning while continuing to drain. If it isn't pausing, the timer is likely defective.
Eric
SamCan
#3 Posted : Wednesday, November 28, 2012 1:52:09 PM(UTC)
SamCan
Don't be too sure of advice to change timer. How close to the following description is your problem?
http://forum.appliancepartspros...08314-no-spin-rinse.html
I have looked at a few other posts with similar problems and none I have seen have a solution!!!
fairbank56
#4 Posted : Wednesday, November 28, 2012 2:19:15 PM(UTC)
fairbank56
Groups: Expert
I didn't advise to change the timer unless the motor fails to pause after drain. If it does pause but still doesn't spin, it's another problem such as the neutral drain mechanism in the gearcase.
Eric
bearkaye
#5 Posted : Friday, November 30, 2012 4:09:53 PM(UTC)
bearkaye
Eric
Thanks Eric. The motor did not pause. I replaced the timer and everything seems to be working well.
Whirlpool Gold Ultimate Care II Washer (Washer Repair)
by jolson 11/10/2008 11:13:15 AM(UTC)
by jolson 11/10/2008 11:09:33 AM(UTC)
