mercea
#1 Posted : Sunday, April 12, 2009 3:38:54 PM(UTC)
mercea
I have a problem with the RR dual burner on my Kitchen Aid stove. I can turn it on, but the temperature control does not work; it stays on and overheats until I manually switch it off.
Can you please advice on what part I need to replace/order, the infinite switch or the surface heating element?
Thanks.
#2 Posted : Monday, April 13, 2009 3:27:53 PM(UTC)
Most likely the problem is a bad switch for this burner. If you need the correct part number then post the complete model number of the stove (there suppose to be 3 more letters and 1 digit after "7").
