Richard Yunker
#1 Posted : Tuesday, November 20, 2012 7:44:21 AM(UTC)
Richard Yunker
I have a Frididare Electrolux dishwasher that is about 3-4 years old. It is not powering up. I do have power to the door switch and from the door switch to the mother board. I ordered a replacement mother board and removed it from its plastic housing to put it in and it still will not power up. I think I have a defective replacement mother board. Does any one have any suggestions? Did I miss something while installing the unit? The unit is level under the counter. HELP!!!:confused:
Simon / APP Team
#2 Posted : Tuesday, November 20, 2012 9:48:32 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
You need to make sure that you are getting 120VAC to the control board between hot and neutral. If you are positive that it's there - try another control board
Part number: 154712101
Simon.
Richard Yunker
#3 Posted : Tuesday, November 20, 2012 1:19:53 PM(UTC)
Richard Yunker
I put my tester to the white and black weir and the tester does not light up. If I touch the black weir and something metal the tester lights up. Is that the issue?
Simon / APP Team
#4 Posted : Tuesday, November 20, 2012 1:41:06 PM(UTC)
Simon / APP Team
Groups: APP Team
You are not getting 120VAC. You are getting only hot side. Check the door switches, junction box connections (behind the toe panel on the right).
Simon.
Richard Yunker
#5 Posted : Tuesday, November 20, 2012 3:00:24 PM(UTC)
Richard Yunker
I got it. I found that the neutral weir was not connected in the junction box in the basement for some reason. It is now working. Thank you for your help.
Simon / APP Team
#6 Posted : Wednesday, November 21, 2012 9:05:29 AM(UTC)
Simon / APP Team
Groups: APP Team
You are welcome.
Simon.
