parker4628
#1 Posted : Wednesday, October 31, 2012 1:22:05 PM(UTC)
parker4628
I have an LG side by side that is leaking water. After you release the button to dispense water form the front, it continues to dispense for a few seconds and then drips for 10-20 sec more. Any help would be great, thank you!!
#2 Posted : Thursday, November 1, 2012 12:29:32 PM(UTC)
Have you replaced the water filter recently?
The model number you posted is incomplete. Verify and repost it please.
parker4628
#3 Posted : Thursday, November 1, 2012 7:02:47 PM(UTC)
parker4628
Sorry, there is a SW at the end. I have changed the filter and run a lot of water to get the air bubbles out. This has been a problem for some time and finally have gotten fed up with it.
#4 Posted : Friday, November 2, 2012 4:45:32 PM(UTC)
One of possibilities is abnormal water pressure in the incoming line. Did you check it?
If there is nothing wrong, replace the water inlet valve.
- The water inlet valve Part number: 5221JA2006D
Here are the breakdown diagrams and Parts for LG LSC27910SW Refrigerator - AppliancePartsPros.com
parker4628
#5 Posted : Friday, November 16, 2012 5:24:10 AM(UTC)
parker4628
Thank you for the help. But I replaced the line and had no change so I did the inlet valve as well and had no change. If anything it got a little worse. Any other ideas? Again thank you very much.
