blossomreggie
#1 Posted : Monday, November 12, 2012 4:19:32 PM(UTC)
blossomreggie
This is my second GE 36" Electric cooktop in 8 years. Its only my husband and myself, so it is not abused. I get the F112 flashing beeping lights. What is the cause.
Thanks.
#2 Posted : Tuesday, November 13, 2012 5:54:26 PM(UTC)
This error code means that the left front burner was overheated. The cause can be a bad sensor which is a part of the heating element, a bad power board or a bad main control board.
You will need a simple multimeter to perform some tests. If you need the correct part numbers, post the end of the model number.
Guest (4)
GE Monogram Cooktop -- No sparks (Oven Repair (including Ranges and Cooktops))
by jim.thornton 12/12/2013 5:53:37 AM(UTC)
GE Monogram Cooktop ignites all burners and doesn't stop clicking (Oven Repair (including Ranges and Cooktops))
by nirvana_1959 4/25/2012 4:42:21 PM(UTC)
GE monogram cooktop no spark (Oven Repair (including Ranges and Cooktops))
by lapswim 2/12/2010 8:38:31 AM(UTC)
ge monogram cooktop (Oven Repair (including Ranges and Cooktops))
by leogon 12/31/2009 11:29:00 AM(UTC)
GE Monogram cooktop disassembly problem (Oven Repair (including Ranges and Cooktops))
by dutch74 12/30/2007 2:49:32 PM(UTC)
