reprice
#1 Posted : Monday, November 12, 2012 3:44:31 PM(UTC)
reprice
I have a dryer that I replaced the heating element on about 6 months ago. It's been working fine up until this past wekkend when it shut down during a run cycle. It was so hot I could smell a slight "electrical fire" type odor. The dryer seems to be overheating and shutting off. After it cools down, I am able to restart but this is a problem that I hope someone can help me with. There's probably a temperature switch that's gone bad. Please help.
Thanks,
Ron
#2 Posted : Tuesday, November 13, 2012 4:57:49 PM(UTC)
Hi Ron,
Remove the wires from the heating element and check for continuity between each of its terminals and the ground. If there is continuity, replace the heating element.
- The heating element Part number: 3387747
Make sure the dryer exhaust line is absolutely clean, the air flow is not obstructed and the vent hose behind the dryer is not twisted and/or kinked.
Whirlpool Duet electric dryer overheats despite replacing various parts (Dryer Repair)
by Manec 8/18/2016 6:49:44 PM(UTC)
dryer overheats/shuts off (Dryer Repair)
by texasoutcast 6/24/2015 7:01:12 PM(UTC)
Electric Dryer overheats and blow thermal fuses (Dryer Repair)
by hall9107 1/29/2015 10:04:39 AM(UTC)
Dryer Overheats (Dryer Repair)
by chrisw73 1/24/2015 5:09:15 AM(UTC)
Dryer overheats when vent is connected (Video) (Dryer Repair)
by shosterman 4/14/2014 10:05:35 AM(UTC)
Old Whirlpool Dryer overheats (Dryer Repair)
by cappy3 8/3/2013 9:43:26 AM(UTC)
Dryer overheats. (Dryer Repair)
by schigara 5/23/2012 1:14:30 PM(UTC)
dryer overheats (Dryer Repair)
by 2501329 4/19/2012 9:05:52 PM(UTC)
dryer overheats/quits (Dryer Repair)
by belindaculwell 11/29/2010 5:12:11 AM(UTC)
Dryer overheats after all thermostats replaced (Dryer Repair)
by Dana-T 9/2/2009 6:44:40 AM(UTC)
by longdestent 5/29/2009 9:15:49 AM(UTC)
dryer overheats, blows thermal fuse (Dryer Repair)
by netsteeler 5/29/2009 8:33:13 AM(UTC)
Dryer overheats on auto dry cycle (Dryer Repair)
by hicks115 4/19/2009 9:56:34 AM(UTC)
knmore dryer overheats (Dryer Repair)
by kenmore broken 10/25/2008 11:26:01 AM(UTC)
Gas Dryer Overheats & Shits Off after 10 mins (Dryer Repair)
by crs2007 4/30/2008 5:08:14 AM(UTC)
