2501329
#1 Posted : Thursday, April 19, 2012 9:05:52 PM(UTC)
2501329
I have this Dryer, Kenmore Series 80, There was a thermal switch burned up when I got it, I replaced it and got it to Heat up, Problem is It gets super Hot. And can't figure out why. What else could fix this?
#2 Posted : Friday, April 20, 2012 12:10:52 AM(UTC)
A model number would be helpful.
Kenmore numbers are usually 3 digits, a period and then 6 to 8 digits.
Many units have 2 thermal fuses.
One kills power to the entire unit.
One kills power to the heating element.
Which one did you replace?
2501329
#3 Posted : Friday, April 20, 2012 7:20:28 AM(UTC)
2501329
answer: The one that attach to the Heater Shell(Case), Two pronged and w/red label. I think it's the Hi-limiter. Could it possibly be the one @ the Exhaust Chamber? I didn't check it because it wasn't burned. or that the wiring is incorrect ? and even thou the switch may cycle, there is continuity of voltage to the Heating element. The model info is gone out of the place where it should be.
#4 Posted : Friday, April 20, 2012 7:48:52 AM(UTC)
Here is my standard blurb on replacing the high limit.
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 10 to 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate it so the thermal cut-off blows.
The hi-limit should have regulated the temperature so the fuse did not blow, that is why there is a new one with the thermal cut-off..
Note: That unless there is another problem in the unit the hi-limit should never have to open. It is just a safety device with the fuse being a backup safety device.
Just in case it is not a grounded element.
With all the below the high limit will also have to be replaced.
Check that the belt is OK.
Check the seals (drum etc) in the unit. The air is pulled over the heating coils, through the drum and pushed out the exhaust. So any large seal leak will pull in room air and the cycling thermostat on the blower will run the unit hot.
Check that the lint filter is not coated with fabric softener residue which greatly reduces air flow.
Check/clean your vent system.
Check/clean the blower wheel.
If all OK you may want to replace the cycling thermostat as it's contacts may not be opening (welded shut)
Whirlpool Duet electric dryer overheats despite replacing various parts (Dryer Repair)
by Manec 8/18/2016 6:49:44 PM(UTC)
dryer overheats/shuts off (Dryer Repair)
by texasoutcast 6/24/2015 7:01:12 PM(UTC)
Electric Dryer overheats and blow thermal fuses (Dryer Repair)
by hall9107 1/29/2015 10:04:39 AM(UTC)
Dryer Overheats (Dryer Repair)
by chrisw73 1/24/2015 5:09:15 AM(UTC)
Dryer overheats when vent is connected (Video) (Dryer Repair)
by shosterman 4/14/2014 10:05:35 AM(UTC)
Old Whirlpool Dryer overheats (Dryer Repair)
by cappy3 8/3/2013 9:43:26 AM(UTC)
by reprice 11/12/2012 3:44:31 PM(UTC)
Dryer overheats. (Dryer Repair)
by schigara 5/23/2012 1:14:30 PM(UTC)
dryer overheats/quits (Dryer Repair)
by belindaculwell 11/29/2010 5:12:11 AM(UTC)
Dryer overheats after all thermostats replaced (Dryer Repair)
by Dana-T 9/2/2009 6:44:40 AM(UTC)
dryer overheats (Dryer Repair)
by longdestent 5/29/2009 9:15:49 AM(UTC)
dryer overheats, blows thermal fuse (Dryer Repair)
by netsteeler 5/29/2009 8:33:13 AM(UTC)
Dryer overheats on auto dry cycle (Dryer Repair)
by hicks115 4/19/2009 9:56:34 AM(UTC)
knmore dryer overheats (Dryer Repair)
by kenmore broken 10/25/2008 11:26:01 AM(UTC)
Gas Dryer Overheats & Shits Off after 10 mins (Dryer Repair)
by crs2007 4/30/2008 5:08:14 AM(UTC)
