Jags
#1 Posted : Sunday, November 11, 2012 3:02:18 PM(UTC)
Jags
Have a whirlpool dryer that makes alot of noise while drying, kind of like a bearing going out. Not a squeay noise though...just real loud. Any ideas?
#2 Posted : Monday, November 12, 2012 2:21:59 PM(UTC)
Most likely the problem is a worn out drum support rollers and/or an idler pulley. It's a good time to inspect and replace the drive belt.
- The drum support roller kit Part number: 349241T
- The idler pulley Part number: 691366
Part number: 691366
- The drive belt Part number: 341241
Part number: 341241
Here are the breakdown diagrams and Parts for Whirlpool LER4634EQ2 Dryer - AppliancePartsPros.com
The disassembly instructions are attached to the post.
Jags
#3 Posted : Monday, November 12, 2012 5:44:14 PM(UTC)
Jags
The instructions will be helpful, I will check those items out. Thank you Gene
#4 Posted : Tuesday, November 13, 2012 2:11:26 PM(UTC)
Jags
#5 Posted : Friday, November 23, 2012 9:05:16 AM(UTC)
Jags
The dryer support roller was the issue, I went ahead and replaced all the parts you mentioned since I was going to be in there anyways. Dryer runs like a dream now...wife very happy....Thanks again.
#6 Posted : Friday, November 23, 2012 2:06:21 PM(UTC)
You are welcome. I'm glad it's up and running.
Happy wife makes a husband happy!
Guest (4)
Kenmore Gas Dryer Noisy When Hot (Dryer Repair)
by atetra 3/21/2013 6:46:11 PM(UTC)
Maytag Dryer Noisy when starting (Dryer Repair)
by jpw050 5/24/2010 6:22:07 AM(UTC)
Dryer Noisy (Dryer Repair)
by foxk49 6/25/2009 5:46:20 PM(UTC)
Dryer noisy (Dryer Repair)
by Pattianne 1/8/2009 5:37:56 PM(UTC)
dryer noisy, leaves black marks (Dryer Repair)
by vsbonner 7/20/2008 2:55:43 PM(UTC)
dryer noisy, leaves bladk marks (Dryer Repair)
by vsbonner 7/20/2008 2:52:36 PM(UTC)
