GPro
#1 Posted : Monday, November 12, 2012 2:16:39 PM(UTC)
GPro
Trying to remove timer (part #3-05207-1) but cannot get dial knob off on Maytag DE612 dryer. Tried prying but didn't budge - afraid of breaking it. Is there some secret to this or is it just stuck?
#2 Posted : Tuesday, November 13, 2012 1:57:22 AM(UTC)
I could not find a breakdown for a DE612 but following is for a LDE612.
They should be the same.
Parts for Maytag LDE612 Dryer - AppliancePartsPros.com
Look at the Control Panel Parts section.
It looks like the center of the knob pops off and then you have to remove a nut that holds the knob onto the timer shaft.
GPro
#3 Posted : Tuesday, November 13, 2012 6:10:58 AM(UTC)
GPro
Bingo! I had removed the stick-on disc in the center of the knob and found solid plastic. Looking at the parts photo for the timer shows a threaded end on the shaft. I went back and realized there is a removable cap in the center of the knob (well disguised) that gives you access to the nut. Thanks for the help!
