dnschrstn
#1 Posted : Monday, November 12, 2012 12:39:16 PM(UTC)
dnschrstn
I need help, I replaced the lid switch but the problem remains the same.
#3356472 is etched in the rear of the machine. I searched the web, best I can tell is it is the 70 series.
dnschrstn
#2 Posted : Monday, November 12, 2012 12:39:47 PM(UTC)
dnschrstn
:confused:
The washer fills, agitates, I replaced switch and I can hear a click when I depress the switch, I hear nothing after the click and and there is no movement.
fairbank56
#3 Posted : Monday, November 12, 2012 12:48:10 PM(UTC)
fairbank56
Groups: Expert
Need a valid model number and more detail as to the problem. Does it agitate? Does the motor try to run during drain/spin?
Eric
dnschrstn
#4 Posted : Monday, November 12, 2012 1:28:51 PM(UTC)
dnschrstn
Eric
Washer fills, agitates, but when it comes to spin/drain for rinse or final spin...there is nothing. With new lid switch, I can now hear the click when I depress the button but still no draining/spinning.
#3356472 is etched in the rear, best I can tell it is a 70 series.
I would really appreciate ANY help you can give me...Denise
dnschrstn
#5 Posted : Monday, November 12, 2012 1:29:51 PM(UTC)
dnschrstn
Eric
2nd reply - I forgot...I hear nothing after the click, I do not hear the motor.
fairbank56
#6 Posted : Monday, November 12, 2012 3:18:03 PM(UTC)
fairbank56
Groups: Expert
That number is the part number for the rear panel, not the model number of the machine. 70 series doesn't mean much, there are many "70 series" models covering many years. This problem is usually a lid switch or timer problem.
Eric
