gregg
#1 Posted : Saturday, April 11, 2009 12:47:17 PM(UTC)
gregg
Hello, my ice machine is stuck in a cycle. the water continually runs over the tray, it will not cycle in or out. The bracket under the tray is not broken. I tried replacing the ice thickness switch as that is the problem sometimes and it did not correct it. Any ideas. Thanks so much.
#2 Posted : Sunday, April 12, 2009 3:56:20 AM(UTC)
I cannot be of much help as I have never worked on one of these.
Hopefully someone else who has will jump in.
I can at least give you some info
Replacement parts for WHIRLPOOL KUIS185FWH1 | AppliancePartsPros.com
Here is the tech sheet
https://www.servicematters.com/d...0Sheet%20-%202180830.pdf
Here is a service manual. It does not specifically list your model but it should be close
https://secured.whirlpoo...5607db/$FILE/4317339.pdf
gregg
#3 Posted : Sunday, April 12, 2009 4:33:43 AM(UTC)
gregg
Thanks, it should be either a broken bracket or the switch, from my limited experience, however the bracket is not broken [it is very corroded under the bottom] and the switch is not theproblem. Just wondering if the corrosion is a factor as far asnot letting it get a reading or if there is another cause.
kichenaid under the counter ice maker (Refrigerator & Freezer Repair)
by jleto 12/24/2011 9:47:42 AM(UTC)
