kenmore 70 series washer goes though all cycles fine but when ir goes into rinse cycle it wont spin it drains water out but if u open and close lid it will spin ive replaced lid switch still same thing ive bye past lid switch and when it goes into rinse cycle it starts to spin and stops right away and wont spin till u open lid again dont think its the timmer cause it goes though all the cycles it just wont spin during rinse or spin cycle it agitates fine need help cant seem to find anyone that can answer this post!!!!:(
Groups: APP Team
Hi. Based on the information you provided the timer need to be replaced.After washer drains out the water the timer pausing fora few seconds allowing the transmission to engage in the spin mode. By opening and closing the lid you are pausing. The timer Part number: 661636
Post the results. Simon.
so i go out and spend $138 total for timer now i still have same problem plus now out $138
ok replaced the timer ( $138 timer ! ) replaced lid switch ($24) replaced clucth assembly ($51) still have same problem every thing works great till it gets to rinse or spin cycle it drains ok it trys to start to spin then stops like the breaks stopped it but if u open lid and close it it then starts to spin !!!
help please not much more i can replace if i new i was going to be $200++ into it i would have just bought new!!:confused: :confused: :confused: :confused: :confused:
Groups: Expert
Operate the machine with the cabinet removed and lid switch bypassed. The washer should fill, go into agitate, at end of agitate mode, motor pauses, starts up again in reverse direction. At this point, it should be draining and the clutch hub should not be rotating. Observe the clutch hub near end of agitation mode to be sure it doesn't start rotating when drain mode starts. After drain, motor should pause again for a few seconds. When it starts back up again the clutch hub should be rotating. If the motor doesn't pause after agitation mode and drain mode, it's a timer issue. If the clutch hub is spinning and the basket is not, it's a mechanical issue (clutch, brake, tub drive block, clothes between inner/outer tub,...etc.) If after drain/pause/restart for spin, the clutch hub is not spinning, it's a gearcase issue. Eric ![UserPostedImage](http://home.comcast.net/~fairbank56/WhirlpoolClutchHub.jpg)
:D works great thx for your help Originally Posted by: fairbank56 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Operate the machine with the cabinet removed and lid switch bypassed. The washer should fill, go into agitate, at end of agitate mode, motor pauses, starts up again in reverse direction. At this point, it should be draining and the clutch hub should not be rotating. Observe the clutch hub near end of agitation mode to be sure it doesn't start rotating when drain mode starts. After drain, motor should pause again for a few seconds. When it starts back up again the clutch hub should be rotating. If the motor doesn't pause after agitation mode and drain mode, it's a timer issue. If the clutch hub is spinning and the basket is not, it's a mechanical issue (clutch, brake, tub drive block, clothes between inner/outer tub,...etc.) If after drain/pause/restart for spin, the clutch hub is not spinning, it's a gearcase issue. Eric ![UserPostedImage](http://home.comcast.net/~fairbank56/WhirlpoolClutchHub.jpg)
Groups: Expert
What did you do to get it fixed???
Groups: APP Team
HI.
Do you mind to share with us what did you do to fix the problem?
Simon.
replacing clutch seed to fix my problem after it drains now it starts to spin so the clutch was my problem thx 4 the help
