2 Pages12>
rkstjarz
#1 Posted : Sunday, November 4, 2012 11:34:41 AM(UTC)
rkstjarz
Groups ready for retrieval: Registered
Gas dryer drum starts and turns on all cycles. No flame on automatic cycles.
On the 'Timed Dry' cycle the ignitor glows, the burner flames on then shuts off after about one minute. The coils were replaced. The flame sensor, control thermostat and high limit thermostat all appear to have continuity.
Readings on timer in off position (not sure if these have any significance):
X to A: no reading
X to B: 3.5
X to C: 3.5
X to S: 3.5
X to TM: 2.3
B to S: 1.3
B to C: 1.3
C to S: 1.3
Test connector: 4.6
Meter lead to lead: 1.3
Will a defective timer cause the burner shut-off?
Thanks in advance for any ideas.
#2 Posted : Monday, November 5, 2012 1:56:31 PM(UTC)
Check the temperature switch for continuity across the terminals 1 & 2 and 4 & 5 at different temperature settings. Post the results.
Here are the breakdown diagrams and Parts for Frigidaire GLGQ642AS2 Dryer - AppliancePartsPros.com
rkstjarz
#3 Posted : Monday, November 5, 2012 5:04:34 PM(UTC)
rkstjarz
Thanks for your response.
Temperature selector switch:
Terminals 1 to 2:
No heat: no reading
Low heat: 1.3
Medium heat: 1.3
High heat: 1.3
Terminals 4 to 5:
No heat: no reading
Low heat: 1.3
Medium heat: no reading
High heat: no reading
#4 Posted : Tuesday, November 6, 2012 1:46:31 PM(UTC)
Originally Posted by: rkstjarz Go to Quoted Post
...On the 'Timed Dry' cycle the ignitor glows, the burner flames on then shuts off after about one minute...
Did the igniter glow after that?
rkstjarz
#5 Posted : Thursday, November 8, 2012 3:24:35 AM(UTC)
rkstjarz
I am not sure about your question. I did not change anything I only tested the temperature selector. The ignitor glowing has not been a problem. The problem is that the flame shuts off after one minute.
Sorry about the slow reply but we have been having power issues here in NJ.
Thank you.
rkstjarz
#6 Posted : Thursday, November 8, 2012 3:27:49 AM(UTC)
rkstjarz
Thank you.
I tested the selector with the power off.
#7 Posted : Friday, November 9, 2012 4:06:27 PM(UTC)
Before we will go further I would like to verify some information.
You said:
Does the igniter glow every time when the thermostat clicks? Does the flame ignite every time when the igniter glows?
Quote:
...No flame on automatic cycles...
Does the igniter glow on automatic cycles?
Quote:
...The coils were replaced...
Did you replace the coils while fixing this problem or they were replaced before?
rkstjarz
#8 Posted : Saturday, November 10, 2012 1:13:43 PM(UTC)
rkstjarz
Hello Gene, thanks for staying with this problem:
The igniter glows once after the start switch is turned on. Then the flame comes on and stays on for about a minute, there is a click and the flame shuts off. The drum continues to turn but there are no more clicks and the ignitor does not glow again for the remainder of the cycle.
The flame always comes on when the ignitor glows.
Only on Automatic Delicates and the timed cycles. It does not glow on the Automatic Colors & Whites cycles.
They were replaced several years ago. I thought it might be the same problem so I just replaced them again so the coils in the machine are brand new.
Thanks again
#9 Posted : Sunday, November 11, 2012 2:13:25 PM(UTC)
Sounds like the problem is a bad timer. If it would not fix the problem and you ordered it from APP then you can return it.
- The timer Part number: 131930600
rkstjarz
#10 Posted : Tuesday, November 13, 2012 3:14:25 AM(UTC)
rkstjarz
Ok, I will try the timer and post the result
2 Pages12>
