amytorp
#1 Posted : 12 years ago
amytorp
We have a Maytag french door/freezer on the bottom refrigerator that isicing up in the back of the freezer and the fridge is not cold. I have beensearching the internet and I'm thinking it maybe the defrost thermostat. Am Ion the right track? And if so, where is this located and what is the best way toaccess this part and test? Would love to make this repair a DIY.
Simon / APP Team
#2 Posted : 12 years ago
Simon / APP Team
Groups: APP Team
Hi.
First you need to check if the freezer door gasket is tight all around.If it is remove the rear panel in the freezer to open the evaporator coils.
Are the coils blocked with snow completely or only the sides where the air ducts are?
You will need the multimeter to check the continuity of the defrost heater and defrost thermostat. They both should show continuity.(The thermostat must be ice cold when tested.)
The defrost thermostat Part number: 67003426
The heater Part number: 67002493
If both parts checks out OK - replace the control board Part number: 12868513
It's located in the control panel in the refrigerator.
Here are the breakdown diagrams and 05-Evaporator Area & Rollers parts for Maytag MFF2557KES - AppliancePartsPros.com
Post the results.
Simon.
PS. Use the blow dryer to melt the snow and make sure that the air ducts on the sides of the evaporator coil are clear.
amytorp
#3 Posted : 12 years ago
amytorp
Simon,
It looks like the problem is the defrost thermostat. Thank you for your help!:).
Amy
Simon / APP Team
#4 Posted : 12 years ago
Simon / APP Team
Groups: APP Team
You are welcome.
Simon.
