Cielo
#1 Posted : Wednesday, October 24, 2012 8:48:29 AM(UTC)
Cielo
I discovered My Washer was not (washing) so I opened the back compartmentand I found the Driver belt had slipped off the driver Pulley, there was also alot of black dust that came from the belt rubbing against the drum. I purchaseda new belt and replace it, but the new one also slip off. After furtherexamination I notice the Pulley was Wobbly, so I removed the bolt to gain accessto the Pulley and notice it had some wear around the center where the boltlocks, which made it, wobble and not fit tightly.
Now here is my question, if I replace this pulley, would this resolvemy problem? Or is there more to this issue, perhaps is damage bearing? That causedthe pulley to loosen, and then the belt to slide off.
Single Mom trying to resolve this issue on my own. I will appreciatean honest knowledgeable answer.
Simon / APP Team
#2 Posted : Wednesday, October 24, 2012 12:46:10 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Open the washer's door and see if you can move the basket up and down. If it moves freely then most likely the bearings are going bad.
But we don't know how long the washer will run before breaks.
You can return the part even if it has been installed.
Here is the pulley Part number: 8182650
The belt Part number: W10388414
Post the results.
Simon.
Cielo
#3 Posted : Wednesday, October 24, 2012 1:50:51 PM(UTC)
Cielo
Thank you for your quick reply. I will Order part and update as soon ia replace the part.
Simon / APP Team
#4 Posted : Wednesday, October 24, 2012 2:58:24 PM(UTC)
Simon / APP Team
Groups: APP Team
Please do so.
Simon.
Cielo
#5 Posted : Saturday, October 27, 2012 5:30:03 AM(UTC)
Cielo
Hello Simon and Concern forum Comunnity
Im PLease to inform you that by replacing the driver belt and driver pulley my washer is working again. At least for now, as i suspect it probably will only give me another year or so, but Hey!! Not complaining!
I want to thank Appliancepros.com for the quick shipping and delivery of my part! I give the an A+.
Simon / APP Team
#6 Posted : Monday, October 29, 2012 7:40:28 AM(UTC)
Simon / APP Team
Groups: APP Team
You are very welcome.
Simon.
