jeffjbrown
#1 Posted : 12 years ago
jeffjbrown
My Whirlpool Top loading washer will not fill. I had a similar problem a couple of years ago and replaced the inlet valve (8181694), so I replaced it again, since we have very hard water. Problem still exists. I have verified that water is coming out of both hot and cold hoses. The washer will go into spin cycle. Where do I go from here? :confused:
#2 Posted : 12 years ago
The model number you posted does not come up. Verify and repost it please.
jeffjbrown
#3 Posted : 12 years ago
jeffjbrown
The correct model number ends in LW0. Sorry for the confusion. The old eyes ain't what they used to be!:(
#4 Posted : 12 years ago
There is something wrong in the beginning of the model number too. Double check it please.
jeffjbrown
#5 Posted : 12 years ago
jeffjbrown
GSQ9633LW0 or GSQ9633LWO.
#6 Posted : 12 years ago
The model number GSQ9633LW0 is the correct one. Good job!
Most likely the problem is a bad ATC (water temperature) control board (inside the control panel) but there is a small chance for the temperature switch to be bad as well. I would replace the ATC board first.
- The ATC board Part number: 3955728
- The temperature switch Part number: 3950358
Here are the breakdown diagrams and Parts for Whirlpool GSQ9633LW0 - AppliancePartsPros.com
