My washer will not wash or spin. It will fill and drain water, at the appropriate cycles. I can hear a loud humming noise whenever it should be washing or spinning.
I am thinking it might be the motor, but I wanted to make sure it was not the control board.
Make sure the belt isn't broken first. Here's the breakdown, Model FWT445GES1Nat
Originally Posted by: Anthony S.  My washer will not wash or spin. It will fill and drain water, at the appropriate cycles. I can hear a loud humming noise whenever it should be washing or spinning.
I am thinking it might be the motor, but I wanted to make sure it was not the control board. Did you ever find out the problems with washer. Mine is doing the same thing and also trips the breaker.
