the oven will no longer heat to above 260'f. when i turn oven on to 350 it displays "error" and automatically goes to 260'f and displays "start ?" auto light on range also no longer works, not sure if these problems occurred at same time. Any advice will be greatly appreciated.
Groups: APP Team
Hi.
Sounds like you may be cooking in Celsius. Open the door, press and hold BROIL for 5 seconds. It should change to Fahrenheit. Repeat to go back.
Post the results.
Simon.
PS. The model number you posted is incomplete. I assumed it's KGRT607HBS9.
