When any burner is turned to Lite, all burners spark but the right rear. This is a counter top range. When the right rear burner is turned to Lite it still does not spark. I replaced the igniter but still no spark. What do I need to replace?
Groups: APP Team
Hi. Check the hi-voltage wire from the ignitor to the spark module. It may leak the voltage to the ground. If it's OK - replace the spark module Part number: 8215557
No, I do not have a way to test the wire. I was hoping do just plug in a new part to fix it.
My fault, not yours.
thank you very much. look forward to using your help in the future.
Groups: APP Team
Hi.
If you switch around the hi-voltage wires at the spark module you can check if this is the wire or the module issue. Don't give up.
Simon.
