wesrussell
#1 Posted : Wednesday, October 24, 2012 9:17:58 AM(UTC)
wesrussell
When any burner is turned to Lite, all burners spark but the right rear. This is a counter top range.
When the right rear burner is turned to Lite it still does not spark. I replaced the igniter but still no spark.
What do I need to replace?
Simon / APP Team
#2 Posted : Wednesday, October 24, 2012 12:15:31 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Check the hi-voltage wire from the ignitor to the spark module.
It may leak the voltage to the ground. If it's OK - replace the spark module Part number: 8215557
Here are the breakdown diagrams and Blower Plenum parts for Jenn-Air JGD8130ADS - AppliancePartsPros.com
Post the results.
Simon.
wesrussell
#3 Posted : Thursday, October 25, 2012 11:56:28 AM(UTC)
wesrussell
No, I do not have a way to test the wire. I was hoping do just plug in a new part to fix it.
My fault, not yours.
thank you very much. look forward to using your help in the future.
Simon / APP Team
#4 Posted : Thursday, October 25, 2012 1:34:37 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
If you switch around the hi-voltage wires at the spark module you can check if this is the wire or the module issue.
Don't give up.
Simon.
