The dishwasher does not clean. After the cycle, I open the door and note there is a lot of mushy soap still in the soap container, although the soap holder flap is in the open position. How can I fix this? Thanks.
Groups: APP Team
Hi.
Please provide the complete model number.
Check if there is water coming inside the d/w.
Simon.
Hello and thanks
Water comes in the machine. The model # is 665.13842K601.
Groups: APP Team
Hi.
Check if the motor is running. If not - check if there is 120VAC to the motor. If motor runs - check if the lower wash arm is unobstructed and jets are clean, next check if the filter under the wash arm is clean.
Simon.
