cas1
#1 Posted : Thursday, April 9, 2009 3:56:15 PM(UTC)
cas1
convection oven stopped working; heats only to less than 150 F.
convection roast works correctly.
Regular oven works.
Is this likely the convection element?
Or a controller?
Or some electronic switch?
Fan works in both cases.
We have no service for Bosch in our area. I am mechanically minded, but have no electrical testing equipment.
I would much appreciate some help.
misterfixall
#2 Posted : Thursday, April 9, 2009 5:52:47 PM(UTC)
misterfixall
acess the convection element +see if it is damaged or check for continuity if ok check for 220 volts
cas1
#3 Posted : Thursday, April 9, 2009 7:52:50 PM(UTC)
cas1
There are 3 elements. Which one is it? Where is the access?
What is the part number?
#4 Posted : Friday, April 10, 2009 8:14:02 PM(UTC)
The convection coil is on the back wall.
cas1
#5 Posted : Friday, April 10, 2009 8:16:33 PM(UTC)
cas1
Thanks Gene.
Guest (5)
