convection oven stopped working; heats only to less than 150 F.
convection roast works correctly.
Regular oven works.
Is this likely the convection element? Or a controller? Or some electronic switch?
Fan works in both cases.
We have no service for Bosch in our area. I am mechanically minded, but have no electrical testing equipment.
I would much appreciate some help.
acess the convection element +see if it is damaged or check for continuity if ok check for 220 volts
There are 3 elements. Which one is it? Where is the access? What is the part number?
The convection coil is on the back wall.
