bjaneski
#1 Posted : Wednesday, August 12, 2009 4:57:22 AM(UTC)
bjaneski
washer is a hydrowave system and we are getting a loud clicking sound when
agitating is happening. never had this sound as loud as now, also getting suds
on top more than normal. looked inside and see nothing abnormal could it be a bearing?
the tub is turning also while agitating !
benlomand
#2 Posted : Friday, October 12, 2012 4:58:09 AM(UTC)
benlomand
I just saw a You Tube video of a problem with this machine as you describe. It showed a support bar that runs from left to right at the top of the tub which was bent causing the tub to drop and the motor mounts to drag and click on the bottom of the case.
GE Washer GLWN5550D0WW trying to test if the shifter disengage from the wash basket (Washer Repair)
by steveh1776 Today at 6:00:43 AM(UTC)
GE washer will spin but will not agitate on the wash cycle (Washer Repair)
by Jodibrewer2002@yahoo.com 2/14/2023 10:39:58 AM(UTC)
GE WASHER MAKES GOD AWFUL SOUND AFTER FILLING WITH WATER (Washer Repair)
by Guest 2/12/2023 5:04:03 PM(UTC)
GE Washer GTW335ASN1WW (Washer Repair)
by jmulc82189 2/8/2023 10:36:12 AM(UTC)
GE Washer Ending Cycle after abt 3-5 mins (Washer Repair)
by FelixSS 2/6/2023 5:37:03 PM(UTC)
GE washer wbse4220aoww (Washer Repair)
by Guest 9/21/2022 2:04:51 PM(UTC)
GE washer- washes clothes, spins, drains then fills w water again (Washer Repair)
by Skep19 9/19/2022 9:36:54 AM(UTC)
GE washer: loud noise when spinning (Dishwasher Repair)
by Guest 8/7/2022 12:54:21 PM(UTC)
GE washer inlet valve problem (Washer Repair)
by Guest 6/24/2022 5:24:03 PM(UTC)
Ge washer tub not spinning (Washer Repair)
by Rconner86 3/17/2022 7:32:41 PM(UTC)
GE Washer wont spin at the high speed GHWN4250D0WW (Washer Repair)
by ssauer40 1/10/2022 4:19:44 AM(UTC)
GE Washer DOOR HINGE PLATE WH01X10653 (Dishwasher Repair)
by Bobgedoor 11/26/2021 6:54:49 AM(UTC)
Ratcheting noise on GE washer (Washer Repair)
by Guest 9/13/2021 1:08:13 PM(UTC)
WH01X10653 GE WASHER DOOR HINGE (Washer Repair)
by Bob defreitas 9/1/2021 9:40:43 AM(UTC)
GE washer just quit (Washer Repair)
by patrick2231 8/1/2021 11:15:14 AM(UTC)
