LG Dishwasher Model LDF6810BB
I'm having an issue where my dishwasher drain pump is continuously running. There is no water in the dishwasher so I believe it is draining but I woke up this morning to see that the dishwasher was still "running". It won't stop until I turn off the breaker but when I turn the breaker back on it starts the drain pump again. What could be causing this?
Groups: APP Team
Originally Posted by: Simon / APP Team ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Thanks, I'm not very technical. Where should I be looking as far as the "cavity"? Do I have to turn the machine over?
Groups: APP Team
When you open the door and look inside - what you see is called "cavity". The drain pump is under it. You can get to it from the sides or back to dry the water. Unplug the unit before working.
Simon.
Originally Posted by: Simon / APP Team ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) When you open the door and look inside - what you see is called "cavity". The drain pump is under it. You can get to it from the sides or back to dry the water. Unplug the unit before working.
Simon. Simon, I appreciate your help with this. I thought the inside was referred to as the tub. There doesn't appear to be any water inside at all (like around the spray arm). Perhaps I'm looking in the wrong place. Should I be looking on the inside of the door?
Groups: APP Team
If you pull the dishwasher out and look from the side or the back you'll understand what I'm talking about.
Did you open the diagrams?
Simon.
Simon, I took the dishwasher out, looked in the sides and the back and saw no water. I also tipped it on its side and water seemed to come out of the door area onto the floor. I let water come out and turned it back on and the issue persists where the drain pump keeps on.
Update:
I tipped it on it's side again with the door slightly open and saw the water is actually coming out of the sump area in the middle of the tub and then coming out the side of the door. Could there be blockage?
I took off the spray arm and looked down inside. there seemed to be a little bit of water near the heating element (I presume it's the heating element). ![UserPostedImage](http://i749.photobucket.com/albums/xx132/JKHamm/photo3_zps3406562b.jpg)
Groups: APP Team
Hi.
Sorry for the delay. Based on the info we have the recommendation is to replace the float switch asm. Part#M090 on the diagram#2.( 4769DD2001A )
Simon.
