2 Pages<12
jhamm
#11 Posted : Friday, October 5, 2012 4:35:46 PM(UTC)
jhamm
Update:
I put the spray arm back on. I had tipped the dishwasher on both sides to see if I could see anything. A lot of water spilled out when it was on either side and the water came out of the filter assembly mesh area.
Also, I had the filter assembly mesh out and shook it and there was still water in there. I don't know if that matters.
Anyway, I turned the power back on to the dishwasher and the drain pump stayed off. I ran a 15 minute rinse only cycle and it went through the process fine and drained properly. I'm not convinced it's fixed, though.
I realize having the water pour out while on it's side emptied it but where would the water be hanging up? While running the rinse cycle I kept an eye on the underneath of it and saw no leaks. Could there be a small clog in the drain hose that would cause this backup but still partially drain?
jhamm
#12 Posted : Friday, October 5, 2012 4:37:05 PM(UTC)
jhamm
Originally Posted by: Simon / APP Team Go to Quoted Post
Hi.
Sorry for the delay. Based on the info we have the recommendation is to replace the float switch asm. Part#M090 on the diagram#2.( 4769DD2001A )
Simon.
Simon, no problem at all. I appreciate the help. Not sure if you saw my most recent update when replying but would you still suggest this course?
Simon / APP Team
#13 Posted : Friday, October 5, 2012 4:39:49 PM(UTC)
Simon / APP Team
Groups: APP Team
HI.
You probably still should replace the float switch asm. and also clean filters and drain nose.
Simon.
jhamm
#14 Posted : Friday, October 5, 2012 4:43:55 PM(UTC)
jhamm
HI.
Simon.
Thanks for your help. I'll order those parts. In your opinion, at this point, I don't need to replace the entire sump assembly? Money is tight.
Simon / APP Team
#15 Posted : Friday, October 5, 2012 5:47:04 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
I don't think you need to replace the sump.
Simon.
Guest (8)
Drain Pump Will Not Turn Off (Dishwasher Repair)
by lhartmann 10/4/2013 4:38:57 PM(UTC)
2 Pages<12
