2 Pages<12
#11 Posted : Friday, September 28, 2012 4:53:54 PM(UTC)
You are welcome Chuck. I hope you are finally out of problems with your home appliances. If there will be anything else we can help you with, drop us a line.
fpfiglia
#12 Posted : Saturday, November 30, 2013 6:31:55 AM(UTC)
fpfiglia
I just experienced this same problem....at least it happened AFTER Thanksgiving!
Question though: Since the lock light staying on prevents me from using the oven ........is there a way to bypass the defective lock so I can use the oven until I can replace the motor unit?
Thanks everyone.
buhrman
#13 Posted : Tuesday, December 10, 2013 3:11:51 AM(UTC)
buhrman
This has happened to me twice and both times I have used a combination of buttons. Never worked the first several times but eventually the light will go off…Here's how: Open oven door and manually hold in the door latch (black button either in the center or on the right hand side). While holding in button, push the clean button, then the start button. I held in the start button for a full minute, released it and held the cancel button for almost a minute. Like I said It never worked the first time and after several attempts I think the computer in the oven needs to catch up, so I waited two or three hours and tried it again and threw up my hands both times. Oddly enough, both times I turned around after a while and the light was off. Other suggestions that have worked for others is holding in the clock button and then hitting cancel…Sometimes tripping the breaker, waiting a while and then flip back on.Hopefully one of these suggestions will save you repair cost…FRUSTRATING SITUATION THAT NEEDS TO ON THE TABLE AT GE
scott11
#14 Posted : Friday, September 16, 2016 8:34:06 PM(UTC)
scott11
Like the others, my oven won't do anything, "Locked Door" is flashing but the door is not locked.
I disconnected the flat flexible cable from the control panel in back. The meter jumped a little when I touched 3 & 5 in the socket in the control panel, and the oven beeped. That means the problem is the door latch assembly -- which I don't need because I don't ever use self-cleaning.
Can I run a jump wire to bypass the locking mechanism?
2 Pages<12
