littleman1
#1 Posted : Monday, September 24, 2012 6:25:30 PM(UTC)
littleman1
I have the front covers off and watched it run with each different water level and it didnt leak as bad with a smaller water level. i am hoping it is just a seal but would like 2 no before i tear into it. any knowledge would b appreciated!:)
#2 Posted : Tuesday, September 25, 2012 3:25:48 PM(UTC)
Originally Posted by: littleman1 Go to Quoted Post
...would like 2 no before i tear into it...
Unfortunately it does not work this way. Guessing never works right. You have to watch the parts inside while the washer is working with different water levels to determine exactly where it's leaking from.
Here are the breakdown diagrams and Replacement parts for Maytag SAV3655AWW WASHER-TOP LOADING | AppliancePartsPros.com
littleman1
#3 Posted : Tuesday, September 25, 2012 5:52:14 PM(UTC)
littleman1
thank u very much gene it leaks way more the higher the water level i have itand it leaks from under the tub so it hits the transmission and spins it everywhere do u think it is worth repairing myself?
#4 Posted : Thursday, September 27, 2012 12:57:43 PM(UTC)
This job is not as simple as many other are and it requires a few special tool to buy. One of them, the break and bearing removal tool, is no longer available. You said that the washer is less than a year old. If this is correct than it's under warranty and Maytag should take care of it.
littleman1
#5 Posted : Friday, September 28, 2012 5:37:46 AM(UTC)
littleman1
no it is a 2004, is it just a seal thats hard to get to? thanks gene
#6 Posted : Friday, September 28, 2012 5:59:49 PM(UTC)
...is it just a seal thats hard to get to?...
Yes, it is. If you feel you can do it, post the serial number of the washer for the correct part number.
littleman1
#7 Posted : Monday, October 1, 2012 6:09:37 PM(UTC)
littleman1
ser.num = 12106894EP model num. = SAV3655AWW
is it worth fixing?
#8 Posted : Tuesday, October 2, 2012 11:44:24 AM(UTC)
The part you will need is triple lip and seal and hub kit Part number: W10116791
Click on the part number and read the answer on the first question in the Q&A section. Also you can find the installation instructions in one of our previous threads: http://forum.appliancepartspros...r-belt-amana-washer.html
Review it and decide if it is worth fixing or not.
