turboca2
#1 Posted : Sunday, September 23, 2012 7:02:47 PM(UTC)
turboca2
My oven and the burners turn on but don't heat up everything acts like it should be working but nothing happens tried unplugging to reset worked for a week now stopped working again is it the oven control Erc. ?
#2 Posted : Monday, September 24, 2012 1:44:34 AM(UTC)
Replacement parts for General Electric JB960BY2 Electric range | AppliancePartsPros.com
Usually when both the stove top and oven elements do not work it is a power problem as they are wired separately.
Note: I cannot confirm this 100% as it is a GE and they like to keep all tech data a secret.
I am not sure why unplugging it got it running for a week but would suspect a bad connection at the wall receptacle or the plug on the line cord.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]Be careful as 240 volts is lethal !!! [/COLOR]
turboca2
#3 Posted : Monday, September 24, 2012 6:38:15 AM(UTC)
turboca2
Looks like the wall plug has gone bad I checked the breaker when I plug the unit back I hear a cracking sound from the wall plug and plug unplugged the unit and found black soot on one of the prongs.
