Starr77x
#1 Posted : Friday, September 12, 2008 3:23:38 PM(UTC)
Starr77x
I Have A Ge Wsm2420d0ww That Has Never Been Used. Been Stored In Garage Since Brand New For Past 3 Years (?). We Hooked It Up Last Night And Everything Works Except For It Won't Stop Filling And Overflows. Suggestions? Thanks!
#2 Posted : Friday, September 12, 2008 4:06:37 PM(UTC)
The water level switch could stuck. Move it forth and back - it might help. If not, then open the control panel and check the water pressure hose (clear plastic hose) connection to the water level switch. Post the results.
Starr77x
#3 Posted : Friday, September 12, 2008 5:49:58 PM(UTC)
Starr77x
Took The Control Panel Off And There It Was. A Mouse Nest. They Chewed A Big Hole In The Clear Hose. Easy Fix. Thanks!
libertyappl
#4 Posted : Friday, September 12, 2008 8:25:18 PM(UTC)
libertyappl
Darn mice get everywhere!
#5 Posted : Friday, September 12, 2008 10:48:56 PM(UTC)
You are very lucky they did not chew drain or fill hoses. I've seen it many times.
suzettemil
#6 Posted : Friday, September 21, 2012 9:01:20 AM(UTC)
suzettemil
I cleaned the clear hose on my GE washer and it works great now! Thank you soooooo much :) you just saved me a lot of money
Thanks again, Suzette
suzettemil
#7 Posted : Friday, September 21, 2012 9:02:15 AM(UTC)
suzettemil
Worked! thanks so much~
#8 Posted : Friday, September 21, 2012 10:15:50 AM(UTC)
You are welcome Suzette. We're glad to hear we could help you out. If there is anything else we can help you with, drop us a line.
GE washer overflows after agitation unless extra small load WCXR1070TAWW (Washer Repair)
by Larry75243 9/16/2013 11:10:36 AM(UTC)
GE Washer Overflows (Washer Repair)
by vbiondillo@norhill.net 8/3/2010 12:53:03 PM(UTC)
GE Washer overflows (Washer Repair)
by doomee 12/15/2009 12:40:33 PM(UTC)
ge washer overflows (Washer Repair)
by hilhp1 10/21/2008 5:30:28 PM(UTC)
