mdg224
#1 Posted : Wednesday, September 19, 2012 7:36:08 AM(UTC)
mdg224
have a roper fridge that wasnt cooling properly thought it was a deforst isssue so let it defrost over night. upon start up i heard the compressor start it cooled for about two hours then stop i tryed to get the compressor to start up again no luck. thinking it is stuck in defrost i replaced the timer apon start up the compresstor kicked in but it didn't cool now i don't hear the compressor kick in any more. could i be looking at the start relay?
Simon / APP Team
#2 Posted : Wednesday, September 19, 2012 9:15:25 AM(UTC)
Simon / APP Team
Groups: APP Team
HI.
If the evaporator fan running check for 1250VAC at the compressor.
If the proper voltage is present check the compressor's pins for continuity between them and the ground.
Compressor checks out fine - replace the relay/overload.
Here are the breakdown diagrams and Replacement parts for Roper RT18DKXBW20 REFRIGERATOR | AppliancePartsPros.com
Thank you. Post the results.
Simon.
mdg224
#3 Posted : Thursday, September 20, 2012 8:23:25 AM(UTC)
mdg224
Originally Posted by: Simon / APP Team Go to Quoted Post
HI.
Simon.
i checked out fan runs 120 volts at compressor no continuity between ground and compressor continuityof 10oms between the pins my question is before i order a overload is there a test for the over load , i did notice that the capacitor was rattleing but so does the overload
Simon / APP Team
#4 Posted : Tuesday, September 25, 2012 7:54:57 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
If you are absolutely sure that the capacitor is rattling - replace it too.
Simon.
Roper refridgerator (Refrigerator & Freezer Repair)
by thewhitefinch 8/26/2008 5:52:42 PM(UTC)
