have a roper fridge that wasnt cooling properly thought it was a deforst isssue so let it defrost over night. upon start up i heard the compressor start it cooled for about two hours then stop i tryed to get the compressor to start up again no luck. thinking it is stuck in defrost i replaced the timer apon start up the compresstor kicked in but it didn't cool now i don't hear the compressor kick in any more. could i be looking at the start relay?
Groups: APP Team
Originally Posted by: Simon / APP Team  i checked out fan runs 120 volts at compressor no continuity between ground and compressor continuityof 10oms between the pins my question is before i order a overload is there a test for the over load , i did notice that the capacitor was rattleing but so does the overload
Groups: APP Team
Hi.
If you are absolutely sure that the capacitor is rattling - replace it too.
Simon.
