hi gene
i just bought a new soap dispenser for my bosch dishwasher
do i have to remove the door to replace it
Yes, you have to remove the outer door panel.
Hi Gene, Is it difficult to replace the detergent dispenser assembly on a Bosch dishwasher? I have model SHU43C06UC/14. Thanks, Jen
thanks gene. it took about me about 20 min. to repair. thank you.
Originally Posted by: justjen  Hi Gene, Is it difficult to replace the detergent dispenser assembly on a Bosch dishwasher? I have model SHU43C06UC/14. Thanks, Jen Jen, It's always about the same. Read all above posts. Gene.
John,
You are welcome. I'm glad you were able to fix it.
Gene, I've got the same issues as gator except a slightly different mod #. Mine is hard to read but I think it is SHU4306UC/06. My soap door will not stay closed. Is there a telltale way to know if I just need a replacement door as opposed to a dispenser unit? Thanks, Mike
I got this replacement part, but it is vented! Doesn't the vent allow water to get inside the door? What is the advantage of the vent? My Bosch dishwasher is SHU5315UC/U11-V02.
thx, Mike
